Looks like a vertical deflection issue with the irregular top and foldover at the bottom, try cleaning connectors and the pots related to the vertical settings to eliminate the trivial things...
Are you comfortable working inside a CRT?
It's most likely capacitors, but could also be other components (resistors, ICs, etc.).
What model is it? Best you can do is find a service manual with waveforms and check if the PSU and vertical section if everything is within spec
