Hey guys, I'm working on a Gould 4074 with a blown high voltage PSU (CRT supply) - my fault
- it sparked half an inch gap between C29 and C39 (down by the Q15 in the schematic). I've got a few questions regarding some of the components (I'll attach a schematic and a picture of the circuit board for reference).
1) D52 Zener diode is a BZX55C100V. I would expect that I'd measure a normal diode drop one way and an open the other way as the multimeter doesn't have the 100V to conduct in the breakdown region. What I've got, however, is a 0.21V drop one way and 0.19V drop the other way which is why I'm assuming the diode is toast. Does it have to be this exact zener or is it ok to get another 100V 0.5W zener?
2) R66 2W resistor with a color code of red, violet, blue, yellow. This appears to be non-existent except if you use gold instead of yellow it's supposedly a 27M
high-voltage resistor which does make sense. Are these special resistors or is a normal E24 27M
2W resistor ok?
3) C31 This was a first for me. It's the same shape as a 1W resistor (pink colored) with a color code of brown, black, orange, black, gray (I don't know which way around is the right way). What type of capacitor is this?
4) R63 is either a 110
or 1k
and I can't decide. Opinions? (Check attached image)
5) The lower part of the PCB is populated with diodes (grey components). These I can't measure at all (open both directions). What kind of diodes are these? Should I be able to measure them in any way?
Thank you for your time and answers (I'm not used to repairing old stuff so I got confused by a few of these
) and have a nice day.
