Hi everyone,
My buddy recently picked up an old Sony PVM-1271Q monitor (dated 1987). When you press the power button, nothing happens, no power light, no tweet tweet, nothing.
I picked it up from him and started checking it out. All the power supply outputs were dead. I removed the power supply board, and started checking for obvious failures. I noticed 2 power resistors (R609 and R610 - in the schematics attached they have them listed as 2 resistors each, on my board there are only 2 total) had cracked solder joints. Fixed them up, still no dice. I replaced all the capacitors on the power supply board. Still no good.
I started poking around with my meter. DC rectifier is OK (I get 167VDC across the main filter cap). I get no B+ voltage on the secondary side. So I checked the drive transistor (Q605), and only get ~4VDC on the collector (with reference to the primary side ground). This seems to fluctuate a little, between 3 and 4V. I removed the TR and tested, seemed OK. I then checked all the other transistors on the board, and they all seem OK. I decided to start looking for schematics. The PVM-1271Q service manual online seems to have the page missing with the power supply board. So, I was able to find the PVM-1371QM (overseas version) online, and the circuit layout is the same, with mostly resistors and caps dealing with the rectified voltage as different values. I do have the values for the 1271Q though, so I can see if anything is bad.
I went through and checked all high wattage resistors, and they were OK, except one was out of spec (R602 was reading 9.4M instead of 8.2M, so I replaced it with 2 3.9M in series). I also checked all the secondary rectifier diodes, and they seem to check OK.
CRT SMPS are new to me. I've never messed with them before. I see there is feedback to IC601 from the H. Pulse. Looking in the upc1394c data sheet, this is to sync with the horiz. flyback to prevent noise in the picture. Is it possible to test the power supply board without this connected?
I checked some voltages. IC601 pin 8, I was getting around 5.29V. Pin 3 was 5.2V, Pin 4 was 2.10V, Pin 14 was 2.791V, and Pin 2 was 5.25V. Pin 6 was 0.05V.
D602 is supposed to be a 17V Zener - I was reading ~ 13V across it, and seemed to drop over time.
One thing I thought was strange - I noticed THP602 (PTC resistor) goes really high in resistance pretty quickly. At room temp, it read 280 ohms. I thought it was my problem, but after looking at the schematic tonight, I'm not sure if this is by design now. I see a "kick" drive, and it looks like during startup, the IC601 drives Q604, Q606, and Q602, which then drives Q605. Then, I'm guessing the THP602 goes high resistance, kills the supplies of Q604, 606, and 602, and then the IC drives Q603, which then drives Q605. Is this correct?
Strange thing, when I pulled the Kick oscillator board out (F2 board), voltage across the zener D602 was 17.2V, and IC601 pin 8 was 6.4V (like the schematics).
Hoping someone can point me in the right direction. Am I wrong in thinking its a problem on the primary side, or should I be looking on the secondary side?
I attached the block diagram and the schematics from the international model.
