Author Topic: Humidity Sensors  (Read 350 times)
Offline mendip_discoveryTopic starter
Humidity Sensors
« on: July 07, 2023, 05:31:48 pm »
With humidity sensors, I know they tend to fail over time as the surface gets contaminated. I saw in a data sheet for one sensor a method of recovering was to heat it up to 90 ish degrees for 20 mins or so.
Is this a known method for recovering sensors? Does it work on most sensors?
I ask as I have one in the lab that has a linearity issue so I would like to see if it can be recovered rather than replacing the sensor. But I also get the odd one in that you can tell is in a dusty room and could do with a clean.
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
