This is my first post here, long time analog electronics repairer and builder, a customer brought an acoustic guitar amplifier for repairs. The amplifier makes use of some digital circuitry to provide reverb effects, which is producing a high white noise.
Managed to trace down the problem down to U201 /RST Input (CS5340-CZZ) Analog to digital converter. Shorting C222 gets rid of the noise but turns off the amp effects, since /RST input is at low level, of course.
I removed C222 and R201, and the noise was still present. However, with those componentes removed, when I tap U201 pin 9 with anything metal (a multimeter probe, screwdriver etc) Noise goes away and I can get the amp to work as expected.
What do you guys think could be causing this? I'm quite new to digital circuits, and do not have access to an oscilloscope. Replaced R201 with a jumper and C222 with a new cap, but the problem remains.
Thank you for your help.
Best regards,
Fran
