Hi i understand i tried 3 version of the options files named in an earlier post. yesterday i descided to change the serial of the scope to just 5M , ST, SM and that worked and with that i finish that project.
i had some serious ACQ errors memory related
Edge not found. proxPtr=0x385a734, distPtr=0x385a734
adjustPhase: Notice: account for BUMP_WRAP, now x = -63
Edge not found. proxPtr=0x385a7a4, distPtr=0x385a7a4
verifyPhaseCal:
HFSTEP Statistics:
7 has Max High Value 0f 88.31
3 has Min High Value 0f 77.00
7 has Max Low Value 0f -72.74
2 has Min Low Value 0f -88.23
1 has Max Edge Points 0f 3
5 has Min Edge Points 0f 0
DEMUXES NEEDING ALIGNMENT:
5 xer(-172) High/Low(80.73/-81.57) Edge(0pnts)
Test "311" - Acquisition-->Memory-->MemData started
acqDataConfCheck: demuxA
Test "312" - Acquisition-->Memory-->MemAddr started
acqAddrConfCheck: demuxG
Test "313" - Acquisition-->Memory-->DataFormat started
digDataFormatDiag: BYTE mode, demuxA
in the logs you will find the U# chip. to by precise look at the Test "31x" they produce other errors, but here you have to start swapping[/b].
and all these lines like: chips are located on both sides of the board in total 64. in earlier posts i made an excel where the are corrolated to the channel numbers.
addr(+0x00005e) = 0x2367be act/exp = 0xc4/0xc
addr(+0x00009e) = 0x2367fe act/exp = 0x70/0x7
addr(+0x00017e) = 0x2368de act/exp = 0x35/0x3
....andon....
all can be related to written above Test "31x"
and errors like these can be correlated to the SPC run even as demux errors
Test "351" - Acquisition-->HFStep-->PhaseCal started
adjustPhase: Notice: account for BUMP_WRAP, now x = 32
adjustPhase: Notice: account for BUMP_WRAP, now x = 31
i had to restore about 10 chips in the lanes. and broken components on the PowerPC board, they were all related to the lines in the connector corner where the display is connected. the LCD didn t work. after fixing that the LCD came up and worked.
