As I said, I have an O/S recovery .ISO file for the Intel NLX board as well as a Ghost image for serial prefix B01XXXX. I've been trying to upload them to
http://global-files.net but it keeps stalling after a few hundred MB. You mentioned that you have an FTP server I could upload them to, can you give me the address?
Here's the console port output of a working scope showing the config. You can use it to program your NVRAM if the battery has died:
boot device : sm
processor number : 0
host name : host
file name : c:\vxworks.st
inet on ethernet (e) : 192.168.0.2:ffffff00
inet on backplane (b): 192.168.0.2:ffffff00
host inet (h) : 192.168.0.1
gateway inet (g) : 192.168.0.2
user (u) : anonymous
ftp password (pw) : anonymous
flags (f) : 0x1008
target name (tn) : target
startup script (s) : c:\dio_rtc.vsh
other (o) : nvfs=0x1000
If your console port output already looks similar, don't change anything for now.
It would be helpful to you if you have a few disk drives to experiment with, so you don't have to lose any progress you (may) have already made. You might want to go back to a previous experiment...
Do note that the calibration NVRAM is backed up by battery as well. What a stupid thing Tek did, have they never heard of flash?
But, worry about that after you get the scope to run.
