Here's the log from a working scope. Note that the battery on the acquisition board is dead so the cal constants were lost. It looks like yours is as well!
EDIT: I thought you were getting data errors on the NVRAM? Your output is missing the early part of the test. Why?
UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
romPost: MPC106 Walking-one passed.
romPost: MPC106 configuration passed.
romPost: First PCI access passed.
romPost: PC87560 Walking-one passed.
romPost: PC87560 configuration passed.
romPost: DEC21554 configuration passed.
romPost: PERFORMING ROM CHECKSUM TEST...
romPost: ROM checksum passed.
romPost: PERFORMING DRAM CELL TEST...
romPost: Enabling data cache...
romPost: Data cache enabled.
romPost: Enabling instruction cache...
romPost: Instruction cache enabled.
romPost: DRAM Cell test passed.
romPost: Disabling data Cache...
romPost: Data cache disabled.
romPost: Disabling instruction cache...
romPost: Instruction cache disabled.
romPost: PERFORMING DRAM MARCH TEST WITH CACHE OFF...
romPost: Writing address to each *address...
romPost: Reading address from each *address...
romPost: DRAM march test passed...
romPost: PERFORMING DRAM MARCH TEST WITH CACHE ON...
romPost: PERFORMING DRAM WALKING-ONE TEST...
romPost: DRAM Walking-one test passed.
romPost: PERFORMING NV-MEMORY WALKING-ONE TEST...
romPost: NV-MEMORY Walking-one test passed.
romPost: POWER-UP DIAGNOSTIC COMPLETE.
Hel
VxWorks System Boot
Copyright 1984-1996 Wind River Systems, Inc.
CPU: Tektronix HPP - PowerPC 740
Version: 5.3.1
BSP version: 1.0.3.0
Creation date: Jun 28 2000, 16:52:12
Press any key to stop auto-boot...
1 0
auto-booting...
boot device : sm
processor number : 0
host name : host
file name : c:\vxworks.st
inet on ethernet (e) : 192.168.0.2:ffffff00
inet on backplane (b): 192.168.0.2:ffffff00
host inet (h) : 192.168.0.1
gateway inet (g) : 192.168.0.2
user (u) : anonymous
ftp password (pw) : anonymous
flags (f) : 0x1008
target name (tn) : target
startup script (s) : c:\dio_rtc.vsh
other (o) : nvfs=0x1000
Initializing backplane net with anchor at 0x1e80000... done.
Backplane anchor at 0x1e80000... Attaching network interface sm0... done
done.
Attaching network interface lo0... done.
PC1 dio device driver installed
Attaching DIO client... done.
Loading c:\vxworks.st...1773480
Starting at 0x200000...
Initializing backplane net with anchor at 0x1de0000... done.
Backplane anchor at 0x1de0000... Attaching network interface sm0... done
done.
Adding 6003 symbols for standalone.
]]]]]]]]]]] ]]]] ]]]]]]]]]] ]] ]]]] (R)
]]]]]]]]]]]]]]]]]]]]]]]]]]]]] Development System
]]]]]]]]]]]]]]]]]]]]]]]]]]] VxWorks version 5.3.1
]]]]]]]]]]]]]]]]]]]]]]]]]] KERNEL: WIND version 2.5
]]]]]]]]]]]]]]]]]]]]]]]]] Copyright Wind River Systems, Inc., 1984-1997
CPU: Tektronix HPP - PowerPC 740. Processor #0.
Memory Size: 0x2000000. BSP version 1.0.3.1.
WDB: Ready.
usrNvFsInit: NAME=/nvram BASE=0xfd0ff100 BPB=512 BPT=8 NB=8 BO=0
nvfs: STATUS: Mounting existing NVRAM file system
KERNEL: THERMAL CONTROL INITIATED
Executing startup script c:\dio_rtc.vsh ...
dbFsIoctl: invalid code 3
cd "c:/progra~1/tdscsa~1/firmware"
value = 0 = 0x0
*0xfec00000 = 0x04b00080;*0xfee00000 = 0x17009002
ppp_parms + 0xfe84f098 = 0xfec00000: value = 78643328 = 0x4b00080
ppp_parms + 0xfea4f098 = 0xfee00000: value = 385912834 = 0x17009002
*0xfec00000 = 0x88a10080;*0xfee00000 = 0x01800000
ppp_parms + 0xfe84f098 = 0xfec00000: value = -2002714496 = 0x88a10080 = ppp_parm
s + 0x8865f118
ppp_parms + 0xfea4f098 = 0xfee00000: value = 25165824 = 0x1800000
*0xfe008002 = 0;*0xfe00800e = 0;*0xfe008012 = 0
ppp_parms + 0xfdc5709a = 0xfe008002: value = 0 = 0x0
ppp_parms + 0xfdc570a6 = 0xfe00800e: value = 0 = 0x0
ppp_parms + 0xfdc570aa = 0xfe008012: value = 0 = 0x0
symSyncTimeoutSet 600000
value = 600000 = 0x927c0
ld <hi32.o
value = 30997472 = 0x1d8fbe0 = Hi32SystemProcessorBoard + 0x998
Hi32SystemProcessorBoard = 1
Hi32SystemProcessorBoard = 0x1d8f248: value = 1 = 0x1
CmdDspDevName = "/dev/cmddsp0"
new symbol "CmdDspDevName" added to symbol table.
CmdDspDevName = 0x1d90f60: value = 31002496 = 0x1d90f80 = CmdDspDevName + 0x20
hi32Drv
value = 0 = 0x0
hi32DevCreate CmdDspDevName,0x80006000,0xa0000000,3
value = 0 = 0x0
ld <cmddsp.o
value = 31003904 = 0x1d91500 = CmdDspDevName + 0x5a0
ld <acqdsp.o
value = 30999168 = 0x1d90280
ld <diagcmddsp.o
value = 31000896 = 0x1d90940
ld <diagModule_wmp.o
value = 28504576 = 0x1b2f200
ld < systemLibraryCode.o
value = 28503936 = 0x1b2ef80
CSSDefaultDioDisable=0
CSSDefaultDioDisable = 0x1b0ff80: value = 0 = 0x0
semInitForQueueCheckLogMsg
value = 31005024 = 0x1d91960 = CmdDspDevName + 0xa00
ld < nvSysLib.o
value = 28424672 = 0x1b1b9e0
ld < bucket.o
value = 28425184 = 0x1b1bbe0
MathMeasCreateMappingFcns = 1
MathMeasCreateMappingFcns = 0x1a98158: value = 1 = 0x1
TmgrExecuteAllMappingFunctionsEnable=1
TmgrExecuteAllMappingFunctionsEnable = 0x1a9488c: value = 1 = 0x1
ld < as.o
value = 28330400 = 0x1b049a0
ld < ifcProxy.o
value = 29749728 = 0x1c5f1e0
acqCheckForCmdDsp=1
new symbol "acqCheckForCmdDsp" added to symbol table.
acqCheckForCmdDsp = 0x1c5f600: value = 1 = 0x1
ld < rtlLibTarget.o
value = 29751840 = 0x1c5fa20 = acqCheckForCmdDsp + 0x420
ld < slotMgrLightLibTarget.o
value = 29640256 = 0x1c44640
sysExtMemAddToPool memSysPartId ,0x02000000 ,0x02000000
value = 0 = 0x0
MathMeasDisableParseExpr = 1
new symbol "MathMeasDisableParseExpr" added to symbol table.
MathMeasDisableParseExpr = 0x3fff400: value = 1 = 0x1
use100Breakpoints=1
use100Breakpoints = 0x1550608: value = 1 = 0x1
pWfmMemPool=0
pWfmMemPool = 0x1aadb38: value = 0 = 0x0
AcqLibFourChannelProto = 0
new symbol "AcqLibFourChannelProto" added to symbol table.
AcqLibFourChannelProto = 0x3fff3a0: value = 0 = 0x0
AcqExecUseChannels=0xFF
AcqExecUseChannels = 0x11f74d8: value = 255 = 0xff
AcqExecHardWireChannelSources = 0
AcqExecHardWireChannelSources = 0x11f74e4: value = 0 = 0x0
CalDiagPowerUpDiagsEnabled = 1
CalDiagPowerUpDiagsEnabled = 0x12e55f8: value = 1 = 0x1
CalDiagLogAtFirstDiag = 1
CalDiagLogAtFirstDiag = 0x12e55dc: value = 1 = 0x1
NvLogDebugTrace = 0x3
NvLogDebugTrace = 0x1b150b4: value = 3 = 0x3
doTekprobeExec=1
doTekprobeExec = 0x12e500c: value = 1 = 0x1
pDbDev = ramDevCreate(0, 512, 1024, 1024, 0)
new symbol "pDbDev" added to symbol table.
pDbDev = 0x3f7f2c0: value = 67105536 = 0x3fff300
pDBfs = dosFsMkfs("/db", pDbDev)
new symbol "pDBfs" added to symbol table.
pDBfs = 0x3f7dca0: value = 66580960 = 0x3f7f1e0
copy ("TDS666.DBF", "/db/TDS666.DBF")
value = 0 = 0x0
dbPath = "/db/"
new symbol "dbPath" added to symbol table.
dbPath = 0x3f7dba0: value = 66575392 = 0x3f7dc20 = dbPath + 0x80
wfmMemInit 0
value = 58186432 = 0x377dac0
jNVInitMgrs
value = 0 = 0x0
TmgrInit(dbPath)
value = 0 = 0x0
rtlInit
value = 0 = 0x0
MathMeasCreateTheMathandMeasurementLibraries
value = 52745280 = 0x324d440
initAcqMapper
value = 52718336 = 0x3246b00
autosetMapInit
value = 52717920 = 0x3246960
mathMapperInit
value = 0 = 0x0
initUtilityMapper
value = 52711232 = 0x3244f40
initWfmXmtrMapper
value = 53121184 = 0x32a90a0
commInit__Fv
value = 0 = 0x0
JanusProxyInit
value = 52671488 = 0x323b400
acqExecInitWfmHdrTemplates
value = 52477088 = 0x320bca0
autosetInit__Fv
value = 0 = 0x0
TmgrHookup
value = 0 = 0x0
rtlHookup
value = 0 = 0x0
hookupAcqMapper
value = 31028096 = 0x1d97380
autosetMapHookup
value = 31028112 = 0x1d97390
MathMeasMapHookup
value = 31027920 = 0x1d972d0
hookupUtilityMapper
value = 31028088 = 0x1d97378
hookupWfmXmtrMapper
commHookup__Fv
value = 0 = 0x0
JanusProxyHookup
value = 0 = 0x0
autosetHookup__Fv
value = 29687368 = 0x1c4fe48 = waitForTransCompleteSem(sem_des*,int*)
taskSpawn "startEmbedded", 50, 0x0008, 100000, startEmbeddedOperation
value = 52319648 = 0x31e55a0
Done executing startup script c:\dio_rtc.vsh
KERNEL: RUNNING TIME SLICED AT 10 TICKS PER SLICE!
-> done
0x2edb420 (aCalDiagExecutor): CCMgr: Recall ACQ cal constants failed!
0x2edb420 (aCalDiagExecutor): --> Initializing to defaults!
0x2edb420 (aCalDiagExecutor): CCMgr: Recall user ACQ comp data failed!
0x2edb420 (aCalDiagExecutor): [13] M: 4,0:21:17,23.00,## FIRST TEST ##
0x2edb420 (aCalDiagExecutor): [14] P: 4,0:21:36,23.00,171,AcqCalInfo(2), AcqCalC
onst(2), AcqCompFactory(2), AcqCompUser(2)
0x2edb420 (aCalDiagExecutor): [15] P: 4,0:21:47,23.00,736,CalStrbs ch7: ACT=18.2
2mV, EXP>400.00mV
done
done
done
connectionTask: handshaking with peer...
connectionTask: handshaking with peer - done.
