Author Topic: HP8595E MIXER ? ?  (Read 811 times)
Offline jean françois
HP8595E MIXER ? ?
« on: June 18, 2018, 09:51:38 am »
Hello,
Thank you for helping me,
with my HP8595E I encounter the following problem "cal signal not found".
I measured with a hp435B the 300MHZ -20dbm is perfect.
On the first range of the mixer 5086-7952 up to 2.9GHZ the measured levels are completely false.
Depending on the frequency it can miss -40dbm.
From 3 GHZ the measured levels are about good and perfect the more one goes up frequency.
Can we think that the 1st Mixer 5086-7952 has broken down? ?
I forgot to reconnect the DCblock on the input.
can I use the 8590 Series Service Manual to dismount the RF part?
  I can not send this device for maintenance.
Please, thank you for your future answers
  Jeanfrançois
« Last Edit: June 18, 2018, 10:10:00 am by jean françois »
Offline Gixy
Re: HP8595E MIXER ? ?
« Reply #1 on: June 18, 2018, 09:38:29 pm »
Hello Jean-François,
You can try to contact Christian Couderc at voilelec.com, he probably can help you.
(https://www.voilelec.com/voilelec/index.php/component/k2/item/509-analyseur-de-spectre-agilent-hp-8595e).
Denis
The following users thanked this post: jean françois
« Reply #2 on: July 03, 2018, 09:01:36 am »
Hello,
thank you for your answer, I will try to contact Christian couderc who is ham radio like me elsewhere.
in any case thanks for the information.
Jean François F1xxx.
