Author Topic: Custom Probe for MI Model 904 Gaussmeter  (Read 527 times)
Offline enut11Topic starter
  • Love building/modifying/restoring test equipment
« on: June 07, 2020, 08:28:47 pm »
I have a Magnetic Instrumentation (MI) model 904 Gaussmeter that came without a probe and would like to get it working.
Have not been able to find any info or manual online.
I believe this type of instrument uses a Hall Effect chip. These chips normally have 3 pins: power, ground and output.
You can see from the photos that the probe socket has 4 wires so maybe the fourth is a shield.
Our local supplier (Jaycar) has a UGN3503U sensor that I will try. It needs a nominal 5v supply.
Ebay has the following linear chips on offer:
https://www.ebay.com.au/itm/10-PCS-AH49E-TO-92S-AH-49E-LINEAR-HALL-EFFECT-IC/122490059728
https://www.ebay.com.au/itm/4PCS-HAL401SF-A-Encapsulation-SOT89-3-Linear-Hall-Effect-Sensor-IC/372247259357
I have never used a Hall chip so any feedback from the Forum would be appreciated.
**NOTE: This thread is now in the PROJECTS section **
« Last Edit: June 08, 2020, 08:21:38 pm by enut11 »
an electronics nut from wayback...
