Author Topic: Damage power supply board  (Read 2540 times)
Offline MixergrTopic starter
  • Country: ph
« on: September 25, 2018, 08:57:35 am »
Dear All, I need your help to identify the exposed part of the power supply board.
Item damage is the D501.
TV3206-ZC02-01(A) KB-5150 Universal Power Supply Board E59670 P/N 303C3206063 is the power supply board.
Is from Grundig tv G32LCD.
Thanks.
« Last Edit: September 25, 2018, 09:02:12 am by Mixergr »
Offline bob225
Re: Damage power supply board
« Reply #1 on: September 25, 2018, 10:38:18 am »
you picture is a bit small, but from other pics on goggle there are a pair of resistors and a mov by the looks of it D prefix makes it a diode
What is the issue with the board ? these a well known for bad caps
« Last Edit: September 25, 2018, 10:54:40 am by bob225 »
  • Country: ph
« Reply #2 on: September 25, 2018, 01:33:17 pm »
the tv receives the orders to open and close (can see the led red-blue) but no sound and no picture. That part D501 blow up the front part gone and we cant to know the specification on it. All the other parts, capacitor, resistance, diode, transistors remove most of them checked and is ok. looks only this part damage .....
Offline rmacintosh
« Reply #3 on: September 25, 2018, 02:14:12 pm »
Shop Jimmy sells a repair kit for this power supply board.
It doesn't indicate what parts are included in the kit but there appears to be a TO-220 diode included.
Is that the only TO-220 diode on this board?
If so, that would be the blown diode on your power supply.
Otherwise shooting them an email to get the parts list for this kit will get you the part number, and outright ask if the included diode is the D501 replacement.
https://www.shopjimmy.com/catalogsearch/result/index/?q=PS1103159AC+Repair+Kit
Offline bob225
« Reply #4 on: September 25, 2018, 02:16:15 pm »
is it just the 24v line that's gone down ?
Offline bob225
« Reply #5 on: September 25, 2018, 02:27:06 pm »
A bit more digging
Dual diode rectifier MBR20200CT ( alternative part SBR20200 or SF20LC30 )
Edit. just come across the schematic https://www.electronica-pt.com/esquema/lcd/tv3206-zc02-01-100w-lcd-tv-power-supply-sch-67482/
« Last Edit: September 25, 2018, 03:07:34 pm by bob225 »
