Well, I think I got lucky!
Inverter back up and running and saved it from the skip!
First IC was installed with a solder bridge I could not remove. When I removed that IC, solder had crept underneath also so luckily I replaced it. Used a finer tip in the iron second go.
Also noticed a slight swollen 470uf 25V cap on the board (marked). Removed it and it had failed (180uf). Possibly this contributed to the MOSFET failure if it was supplying its regulated power.
Scavenged a replacement from a scrapped power supply.
Origin Energy can start paying me again !
Thanks for the support!
I will add this to the previous Miele induction cooker repair (power MOSFETs, diodes and capacitor), and call it a good 12 month!
