Author Topic: damaged usb 3 controller  (Read 1062 times)
Offline pitfermiTopic starter
« on: September 15, 2020, 10:31:26 pm »
i have an Asrock Z97 extreme 3 motherboard. I accidentally shorted vcc and gnd on one of the rear usb 3 ports (4 in total) when working with a usb-ttl adapter.
since then, the max read/write speed has dropped to around 144MB/s. I tested with various usb 3 devices and disks, i can confirm that they are fine. the 2x front usb 3 ports work at full speed, as they apparently have a separate usb controller since they connect to the motherboard with a usb 3 header. all usb ports work fine, but apart from the reduced speed, i get some random reconnects/disconnects on some devices. im sure something is damaged in there.
what is the procedure/steps to repairing a usb controller? I emailed asrock couple weeks ago but they never responded. any ideas?
« Last Edit: September 15, 2020, 11:40:45 pm by pitfermi »
Re: damaged usb 3 controller
« Reply #1 on: September 15, 2020, 11:17:32 pm »
by the way, i have tried several drivers and check for hardware changes, disabling/uninstalling the controller on windows, no luck. thus i assume the problem is physical.
Offline Haenk
« Reply #2 on: September 16, 2020, 05:44:19 am »
Use a PCIe-card as a replacement.
Online magic
« Reply #3 on: September 16, 2020, 10:37:00 am »
The controller is probably built into the chipset. But it doesn't care about VCC short to ground. Either you shorted something else or maybe it's a problem with the power supply on this port. Is it still 5V as it's supposed to be?
« Reply #4 on: September 17, 2020, 12:09:09 am »
all 4 ports have the same problem. power is still 5V
I'd rather try to repair it myself than spend money on additional hardware. there are already 4 ports on the rear of the motherboard.
Online magic
« Reply #5 on: September 17, 2020, 05:13:47 am »
5V also under load?
In general, you are probably screwed. AFAIK there isn't much in there - polyfuses on the 5V line, maybe some ESD diodes on the signal lines and the lines go to a chip. The chip is likely difficult to replace (or even buy) and it might be the southbridge for all we know. Check in device manager what controller it is.
« Reply #6 on: September 24, 2020, 06:56:58 pm »
so, it seemed to be a software issue. reinstalled windows, problem fixed. not sure what happened there
