Author Topic: Danfoss (SMA) flx pro solar inverter error 361  (Read 818 times)
Offline monchichackTopic starter
« on: May 08, 2021, 08:32:11 am »
A number of inverters on site are failing due to error 361 which suggests either output protection relay or relay drive transistors maybe at fault.
Upon opening an inverter I've noticed a failed smt cap on the output driver section.
Has anyone got any experience with these devices? Once repair is completed, is there a software reset procedure?
Thanks
Offline Mohamad
  • Country: ir
Re: Danfoss (SMA) flx pro solar inverter error 361
« Reply #1 on: January 13, 2024, 12:15:50 pm »
Hi I have same problem on my site and a number of inverters are failing due to error 361.Were you able to solve the problem?
