Author Topic: Dangers in opening a 240V vinyl turntable?  (Read 1188 times)
Offline bleakTopic starter
« on: January 16, 2020, 02:42:00 am »
Hi all, first post :D
Just wondering if there's any particular things I should watch out for when opening a direct drive turntable for repair?
I have a 240v Gemini SA 600 turntable that I am thinking of opening as it is not rotating but otherwise seems to be operational. Of course it has all the standard, scary-sounding warnings on its case.
Note: I am very very novice with electronics.
Thanks o/
Offline james_s
Re: Dangers in opening a 240V vinyl turntable?
« Reply #1 on: January 16, 2020, 04:32:18 am »
As long as you unplug it first there is not really any risk to yourself. There could be a risk to the turntable if you do not know what you're doing though. In most cases there is no visual indication of a fault.
Offline shakalnokturn
« Reply #2 on: January 16, 2020, 08:58:39 am »
I've repaired a few of those atrocities in the past, usually the motor driver IIRC.
The only direct drives I've seen used by DJ's that were of decent design were Technics, all the others are a waste of money IMHO.
Edit: First check platter bearings /grease haven't stiffened.
« Last Edit: January 16, 2020, 09:16:41 am by shakalnokturn »
Offline tggzzz
« Reply #3 on: January 16, 2020, 09:23:20 am »
Make sure there is no chance of mechanically damaging the tone arm.
Offline andy3055
« Reply #4 on: January 16, 2020, 05:54:34 pm »
For good measure, remove the head shell with the cartridge and the stylus before you start on it. Those are the most delicate in the whole unit. Removing the shell is just too easy to even write about!
Offline james_s
« Reply #5 on: January 17, 2020, 07:07:34 pm »
It is on some, but many turntables do not have a removable headshell. I just remove the stylus when I work on mine.
Offline JohnG
« Reply #6 on: January 17, 2020, 07:46:41 pm »
The most serious danger is that you will amass a giant collection of vinyl and that this could fall over and maim or injure someone.
Cheers,
John
"Reality is that which, when you quit believing in it, doesn't go away." Philip K. Dick (RIP).
