Hello again.
With the help of a friend of mine, I was able to confirm that, at least, part of the board of this steam iron is working ok. We could trace most of the expected voltage values from the mains input on the board until the uC. We measured voltages at the input and output of a buck converter, at the input of a 3 terminal voltage regulator and at the input of the uC. So, at least this path is working fine. I hope there's nothing else damaged.
Now what I found out by chance while I was inspecting several other points in the steam unit, was that the heating element of the steam using has 2 fuses. One of them is a thermofuse like this:
and while I was measuring voltages I ended up trying to measure a voltage at this fuse (wrt to mains ground) and when I touched the fuse with the multimeter probe, I noticed a spark and the heating element heated up a little. So, I tried again and kept pressing the fuse's metal plates and the stem heating element heated up as it would normally do.
Now, there are 2 ways this can turn:
1 - I replace the fuse and solve the problem, assuming a peak voltage of my house electrical network blown the fuse
2 - I replace the fuse and the same happens, proving that something else is damaged.
What you guys think I should do?
