Hey guys,
I'm looking for some advice on sourcing an original FUJI part nr.
6RI30G-160.
I just aquired a VFD/inverter unit by Speecon (7200G3 7.5 kW/10hp). The story is that the factory had a power surge and the inverter stopped working. Every time it was connected afterwards it blew a fuse.
Testing for continuity on the inputs reveals shorts between all 3 input phases and the neutral.
Diving a bit deeper we arrive to the affore mentioned diode bridge where all 3 phases meet for the first time. The bridge is shorted between all 3 phases and the negative side of the DC side of the brige. Positive to negative side acts as expected for 2 diodes in series.
At this point I haven't desoldered the bridge yet as I need to figure out how to do it with the massive posts. After that I should be able to 100% confirm it was the bridge that got blown (I'm almost 100% even at this point).
My question at this point is:
If it turns out that the brige is at fault should I just get one from China from eBay (basically I'm afraid of getting a subpar part and it blowing up at full power) or is there a better way to source a reliable part?
Thank you for any help you can provide and have a nice day
