Author Topic: Datel/GE DVC-350 Calibrator - Replacement LCD display needed  (Read 1741 times)
Offline mcmahonggTopic starter
  • Country: ie
Hi
Anyone know of a suitable model number and/or supplier for replacement LCD display needed for Datel/GE DVC-350 Calibrator?
It's a 40-pin, glass panel type, 7-segment 4.5 digit LCD display.
The LCD is driven by an Intersil/Maxim  ICM7211MIPL display driver
Backplane connections on Pins #1 and #25 and the pins for the rightmost digit are:
a4  #22
b4  #21
c4  #20
d4  #19
e4  #18
f4  #23
g4  #24
With decimal points *probably* on #5, #9, #13, #17.
thanks for any advice
Gerry
« Last Edit: May 02, 2018, 12:10:00 pm by mcmahongg »
Offline syzygy
Re: Datel/GE DVC-350 Calibrator - Replacement LCD display needed
« Reply #1 on: June 07, 2021, 10:52:59 pm »
Hi Gerry - did you ever find a source for the glass?  I'm looking now (glass is 'leaking' black), and the manufacturer (calibratorsinc.com) phones don't work, and their website seems....old.
  • Country: ie
« Reply #2 on: March 28, 2022, 11:58:23 am »
Hi - sorry I've only just seen your message. No - unfortunately I was never able to find a replacement LCD for the devcice.
Offline PureZX
« Reply #3 on: August 11, 2022, 03:49:29 pm »
I have a faulty Datel DVC-350. LCD looks good, in fact the unit is in reasonably good condition. Looks like it's been kept in the carry case. Battery compartment cover is damaged and wont stay in. It's been on my 'to do' shelf for quite a while as I can't find any schematics. I have a data sheet and the manual but sadly no schematics.
Mike
Offline coromonadalix
« Reply #4 on: August 11, 2022, 05:02:19 pm »
i would search for ICM7211  projects, you could find an almost identical or suitable lcd ??
i think  you have an lcd with pins  on the glass ???
or search Ebay  for used or defective units   taking a gamble ??
not sure datel had oem / clones variants ???
