Author Topic: Datron 1061A Calibration key  (Read 904 times)
Offline Ade911Topic starter
« on: September 14, 2023, 07:22:40 pm »
Hello support group,
Does anyone in the UK have a spare Datron 1061A calibration key I could purchase from them please before I rip the switch out and replace.
Many thanks
Offline Macbeth
Re: Datron 1061A Calibration key
« Reply #1 on: September 14, 2023, 08:33:29 pm »
Check out Usagi Electric or Lockpicking Lawyer for those totally worthless keyswitch defeats. A lockpick is more fun than a genuine key.
Offline meandeev
« Reply #2 on: December 18, 2023, 09:48:31 pm »
it´s maybe the same like in the Datron 4000/4200 calibrators: a normal Yale DC751 - as you are in UK it should be cheap as a test...
Offline TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« Reply #3 on: December 19, 2023, 02:53:27 am »
I can confirm that the cal key is the same for all the multimeters and the 4700 calibrator.
I actually had a key that was close, it went into the lock OK so I pulled the switch apart to figure out where to file the key to get it to work, from that I had a few more cut for my devices, I covered it in a video of mine on a 1062 if I remember rightly.
attached is a photo of the key I found on the forum some time ago, it is almost the same.
My key is an CH751, and the ones I had cut are a ilco N54G type.
Here is the video where I pull the lock apart:
« Last Edit: December 19, 2023, 02:59:47 am by TheDefpom »
Cheers Scott
