Thank you for the reply Gyro
I have the manuals and have went through the common faults. Powersupplies, Optocouplers and relevant logic ic's. i think i will replace all tantalums on every board as i have repaired a 1061 and 1071 before and both had problems with unstable tantalum caps.
i will try to re-seat all ic's again as the 1065, was working fine last week and have been working for over two year since the first repair.
As for the 1081 i need to re check all the power rails again using my scope. May be the lm309 that is acting up. or maybe a bridge rectifier or tantalums.
I have went through most of the datron posts here and they are of great help
On my 1071 the main problem was the bootstrap power supply that produced about + - 12v on the outputs. The problem was IC M16 on the analog board
