Author Topic: Datron 1082 multimeter firmware issue ?  (Read 900 times)
Offline macflyTopic starter
« on: May 02, 2020, 03:48:20 pm »
Hello,
I observed a strange phenomenon on my Datron 1082 DMM:
Here you can see it, measuring a stable 10V source after one hour warm-up:
The 1Hz-filter and the 'Hi-Res'-mode  is activated.
To have a more stable result, I tried the 'block-mode', in this case with n=10.
What then happended makes we wonder:
The conversion result ist 25 (!) Digits lower. If I switch the block mode off, the result will
be same as before. Changing the number of block-mode cycles to e.g. 20 has the same result.
For me this looks like a firmware error … but I am not sure.
My Datrons firmware version:
My question to other DATRON 107x- and 108x-user:
Does your Datron do the same ?
Thanks
macfly
« Last Edit: May 02, 2020, 03:55:29 pm by macfly »
Genius is one percent inspiration, ninety-nine percent perspiration (Thomas Alva Edison 1903)
Offline dacman
Re: Datron 1082 multimeter firmware issue ?
« Reply #1 on: May 02, 2020, 06:13:27 pm »
I suspect a bad IC contact or a bad IC.
Offline picburner
« Reply #2 on: May 02, 2020, 06:26:05 pm »
If you want to do a check here is the firmware of a Datron 1082, but I don't know if it is the same version.
« Last Edit: May 02, 2020, 06:28:19 pm by picburner »
« Reply #3 on: May 02, 2020, 09:08:25 pm »
Hello picburner,
thanks for the link. I have just no EPROM programer and the right EPROM type, but it's worth a try.
@ dacman
I agree with you. A hardware issue is most likely.
But the point is, that both measure-modes use the same hardware.
Regards,
macfly
