I did a big repair series fixing my Datron 4700, I replaced every single 25V tantalum in the unit with a 35V, I suggest you do the same...
Also re-cap the main power supplies whilst you are at it, there could be excessive ripple coming through, don't rely on testing the caps low voltage testers don't tell you everything, measure the supply ripple with a scope.
