Hi George,
I have startet the refurbishing process of my 1082 a few years ago, replacing nearly all electrolytics.
The supply voltages are within their tolerance and have low ripple. But till now I will start to reseat the IC's.
Thank you!
macfly
DONT reseat the memory IC's otherwise you will lose your calibration data, all the other IC's are fine to do.
I am in the process of repairing 2 Datron 1062 units at the moment (videos will be on my channel in the near future).
A common failure is the optoisolators on the analogue board, with age their performance drops and causes issues, you can still get replacements, MCT6 and 6N136. the MCT6 are actually binned components selected for the speeds (red dot/white dot), this may or may not need to be considered when replacing them.
You will need to replace all electrolytic, they ALL fail, the ones on the analogue board are known for being a common failure, in both of my units every one of them had very bad ESR/dissipation.
