Hey everyone,
I have a T-Con board from an LED TV that is not working. There is an ISL98602IRAAZ that does not seem to be doing anything. There is a testpoint labelled 1.2V beside the chip which has no voltage. I have read that the ISL chip on these boards often fails so I ordered some replacements. However, after replacing the chip, I still get no output. I replaced the chip a second time in case one of the cheap Chinese chips I bought was bad. Still no output.
Making things more difficult, there is no datasheet available for this chip online other than a pinout with short pin names.
I have 12V input on pins 5,30,31,36,37,38
1.22V on pin 25
4.7V on pin 24
4.4V on pin 18
The enable pin has 0V which seems like a problem to me. I tried tracing the pin out on the board but cannot find where it goes as it is a multilayer board. I tried putting 3.3V on the enable pin but there was no change.
I'm not sure what half of the pins do which makes troubleshooting the problem quite difficult.
Does anyone have any ideas on things to check for?
Thanks
