Hi fitz1,
I think the motor uses permanent magnet for its field. If it is so, do you have a regulated power supply?
If you have you should test the motor with this without mechanical load (if there is a belt please disassemble it)
To do so connect the motor to the supply and start from 0 volts (adjust the current to maximum at ther supply).
If the motor is ok it will start turning under 10V. (You may test it with a car battery, but place a 10A fuse for your own safety. The motor should run with 12V, but slower and with less power ...)
Good luck
EMUD
