Q632, Q635, Q636 replaced with equivalents.
Q640, 641, Q642, Q643 replaced on the radiator but not connected on the board. If I connect them, the consumption increases and I have nothing to measure. If not connected, the emitter from Q635, Q636 becomes asymmetrical to the output rail. In this topology I think it must be 2 resistant as a load against the table.
All transistors Q602 .... Q651 checked as diodes, are ok.
The 48V / 5W bulbs - in series with ± 50V power supply, connected after electrolytes - light up very weakly but they also supply the functional channel (on the mainboard there is no power separation between the channel).
### As additional information, with R603 = 47K disconnected (IC601A seems ok now with R603 disconnected), the system starts at + 40V (bases Q635, Q636) so that after 20 seconds it starts to decrease rapidly (in about 3 seconds) until + 30V, then to quickly reverse the polarity (in about 2 seconds) decreasing to -40V, a value that remains constant for the rest of the measurements. Once stabilized at -40V, Q621 seems saturated.
I changed C616 = 100µF / 16V to 100µF / 100V, but no any changing in the above transient mode.
C603 47µV / 16V and C605 3.3µF / 50V are harder to reach, I haven't changed them at the moment. I don't see any other electrolytes to delay reversal.
The timing of the reversal is not related to protection relays triggering.
R673 = 220 ohms slightly discolored but at the nominal level.
