Hiya, new member here. I'm an amateur hobbyist inspired by EEVBlog youtube videos!
I got a good deal on a GW Instek 0-30V dual tracking power supply... except that it was poorly packed and was damaged in transit. I took it apart and found only minor damage, mostly broken plastic bits. However, the PCB that holds the output terminals was cracked and has a broken trace. I fixed the trace with a jumper wire, and now the slave channel works! Now the other problem that I was able to find is a broken 10k pot on the master channel.
The pot says "682F 10KB2" and it looks like a pretty standard item. However, I wasn't able to find an exact match searching Google and eBay for "682F 10KB2". I am going to venture a guess that this is a linear pot, but I am not sure what the "B2" or "682F" mean.
I measured the shaft from the bottom of the threaded portion to the tip: 15.2mm. Can someone help me source a suitable replacement pot please?
Many thanks!
