Did you try resetting before taking apart?
Unplug from PC, hold escape down, while still holding esc plug keyboard back in.
About 5 seconds after plugging back in, release escape key and it should spring back into life (might have to try two or three times).
I use mine (K63 but reset method is the same) wired on PC and Bluetooth elsewhere, quite often if I’ve been using it in Bluetooth mode, the PC won’t recognise it until I reset it.
