i measured one right and you wanted me to measure in the same way on both?
Im getting frustrated again :/
this is obvious stuff, you have two identical 4901NF parts, yes measure BOTH the same way
or did i missunderstand the picture? i measured like this:
good
Maybe i should've done it like this?:
take a good look at 4901NF, use a loupe/macro in your camera, look at the pins and what they connect to, notice something funny? some pins connect to the same track on the board, now look at the picture you just drew
I got slightly confused here as the word "Transistor" was used. Is that the tiny thing on its left? Cause the 4901NF's are power mosfets?
https://en.wikipedia.org/wiki/MOSFETThe metal–oxide–semiconductor field-effect transistor (MOSFET, MOS-FET, or MOS FET)
Also to make sure i am gonna do the SIC780's correct. on the pic you drew on 6
all 8
of the SIC780's the lines are different.
I wasnt pixel perfect ;-)
I woudlve thought i had to measure the same way on all of them.
Is this because it is basic
Vin to GND
GND to SW
and SW to VIN?
as you showed in this pic:
yes, on
all 8 SIC780 pins market in same color are connected together. Lot of power going thru = need to use couple of pins tied together. This is why Vin and SW have 7 pins connected to same tracks.
There are 3 groups of transistors on your card. Judging from pictures (so ~99% sure):
1/ 2 powered from PCIE, Q16 4901NF for ram + U6 SIC780 for GPU - the bare minimum just enough to display that 'not plugged in' message = 100% working
2/ 3x SIC780 U7 U8 U9, powered from right most external socket, supplied thru L17 = maybe ok, maybe bad
3/ 4x SIC780 U10 U11 U12 U13, powered from left external socket, supplied thru L18 (
open circuit) = 100% broken here
no idea where Q15 4901NF is connected, im guessing its in group 2.
now we need to check if Q15 measures same as Q16, and if U10 U11 U12 U13 measure same as U6 U7 U8 U9.
Obviously Vin to GND will be common among transistors in same group.
Maybe you should "TRY" also to ask them for the circuit schematic if not the block diagram and if not the troubleshooting flow chart or the initialization flow chart just in case the 2 problems are not resolved by the fuse. Better still, ask the fuse and freezing question to them. Don't we all like to learn ?
I wouldnt, this would signal you have absolutely no clue about what you are doing. This circuit is a very basic DC/DC buck converter, if you look at the back of the card there are controller chips there, circuit is based on their reference applications. We only care about the values of broken discrete components - so far one fuse, most likely 8 Amps.
