there are only 2 situations I can think of that made fuse blow in the first place:
a/ removed limit let card pull >144W from that one rail, nothing mysterious here
b/ removed limit let card pull close to 144W which somehow glitched/fried controller/gate driver? getting transistor/s stuck low/pulling supply to ground, and they turned out stronger than fuse (50A per datasheet)
b wouldnt let the screen stay frozen even for a fraction of a second, if would go straight to no signal
frozen screen = parts of gpu still running until watchdog ticks and restarts driver/emergency shut downs computer.
there still might be something wrong in power sensing circuit, one step at a time
Ok new update.
I am now really frustrated...
First time nothing, no freakout, no picture. Nothing.
I took it out, on to the bench and thought for a bit. Then i decided to resolder the fuse to the board threw it in my pc again and IT WORKED! Everything worked. I restarted one time to get full resolution on and all my 3 monitors. It fucking worked. Temps were fine, Everything was in perfect order. Both in GPU-Z And MSI Afterburner!
So i thought hey why not reinstall drivers aswell since i've been using a really old card up until now. I opened driver sweeper. Clicked okey dokey on "Reboot to safe mode" And boom, the card is dead again...
I have restarted. Replugged the gpu and everything. No freakouts. Nothing. Cant install drivers "No compatible card detected" it's not recognized in GPU-Z. What the actual f is going on?! This was exactly how it acted before i resoldered the fuse.
EDIT: I have managed to make it work 2 times now. I am currently on and installing drivers. It seems like the pci connection is extremely unreliable for some reason. It is clean, but i don't expect 100% for it to work after a restart. And last time it worked i said YES And started screwing the screw on the PCI Slot in to straighten the gpu and that made the screen black. First black screen while the pc was on. (This is why i think it's an issue with the PCI Slot)
This card is teasing me so hard right now....
