For anyone trying to fault find this scope i think the procedure listed for the military version is probably the best plan.
Lift up the resistor on the emitter of the two push pull transistors R949 listed a 1 ohm.
put the scope on a variac if you have one and slowly wind the ac up to about 80v monitoring the voltage between 950 and 940.
If it comes up to 43V then the pre reg is fine, If no 43V then the pre reg is the issue.
if you have 43V now start looking around the power transformer.
In its click click overcurrent state there is no point checking around the pre reg as the voltages are constantly being set and reset by the overcurrent sense around the 0.2 ohm resistor which resets the pre reg chip.
Check all the diodes on the o/ps and measure the resistance as follows:
-8.6 TP500 114 OHMS
+8.6 95 OHMS AT W975
+5 330 OHMS AT W 985
+30 905 OHMS AT W965
+100 12.5K OHMS AT W966
IF YOU FIND ANY REALLY LOW THEN CHECK THE CAPS BY LIFTING ONE LEG.STILL LOW THEN INVESTIGATE FURTHER BY LIFTING THE LINK OR LINKS IN THE CIRCUIT CONCERNED.
If that fails you may have a shorted turn in the transformer or a cracked ferrite former.
Only way out may then be to look for another transformer.
The former on these has 22 pins and a very imperial inch layout so any attempt at a wind with a different former would be difficult at best.
The HV wind is 1025 T #39 for a voltage of -2050V and i know someone has attempted it and succeeded but its probably difficult.
+30 is 16T #23
+100 37T #31
+5 3T #24
+8.6 and -8.6v 5T #24
filament 6.3v 3.5 T #24
The main core is also encapsulated with resin so if you just have shorted turns then it would be very difficult to rewind without rewinding it completely i guess and re-encapsulating in a pressure chamber. Otherwise you would probably have corona issues and flashover at 2K plus.
I am waiting for another transformer to try as i have a broken ferrite core and have exhausted all the above.
I will post the result after i fit it....who knows if it will. I am not sure when i will give up.
Actually if it does not fix it then the problem could be the inverter itself or the feedback self oscillating transformer although its very low current and unlikely to break. watch this space.
Like the idea of seeing if it will run on a 43v independent supply but you would need to monitor the supply current.
It may be that it will run on the 43 with more current if the no of turns has reduced in the primary 20T+20T #25 but the core may then start to saturate due to the reduced number of turns and overheat as the resistance is now moving towards the resistance of the wire itself .
20T of #25 looks like 0.2 ohms at a path of 94mm ish which is an instant short .
Continuing my quest on the 2235 scope and while waiting for another transformer i decided to tear down the old one.
Waded my way through the first two winds on the first layer which has plus and minus 8.6 with 5 turns and wound next to it plus 5v with 3 turns all Bifilar and hit the first layer of heavy duty tape...what is that stuff? about 3 mm thick and ran in to the HV wind. This HV wind actually straddles the pins on the former from pin 8 which is grounded to an exit point at the top of the transformer where the #39 wire is soldered to a HV wire before exiting.
On looking at the connection between the very fine wire and the lead out i noticed that around the solder connection it was very black and sooty...is this likely my problem i wonder. If it is i wonder if the multiplier has been affected.....time will tell
