Not good news ahead, it seems.
I've removed several parts by now:
-U8, C4, C5, C6 and C7. The short circuit between V0-V3.5 remains.
-U10, wich has also connection with V0-V3.5, and also short circuit present.
And all this components are OK. No short circuit on any of them. Wich is to be expected, as far as the short remains without them on the board.
So now, and after a long research over the schematic, the only part that I guess that needs to be checked is U2, wich is one of the mains components, and is the manager of the measurements, I think.
What do you think should be my next step? Remove U2 and check it after? U2 seems to me a tough one, as far as its pads are really tiny. And moreover, I dont' know if it's posible to replace that component. I've seen that it's cheap (about 5$), but too dificult for me to replace. I have a hot air soldering station, but I'm not that skilled with it. Also I don't know if it comes ready to work out-of-the-box, or it needs some programming, wich should be impossible for me to do.
Anyway, I'm not afraid. I assume that my 71E is lost, so I'll be glad if any hope still stands.
Thanks for your help, and regards.
