Author Topic: Debugging an ATX power supply.  (Read 1035 times)
Offline westfwTopic starter
« on: August 31, 2020, 11:30:13 pm »
I have an ATX power supply that has gone "wonky."  The computer it powers will run for about 5 minutes when first turned on, and then goes into a loop where it powers down and starts up again, not quite lasting long enough to boot.
It seems like it's likely to be a classic "bad capacitor" problem.  (replacing the Supply fixed the computer that it was in.)
Any hints on how I can narrow that down to WHICH capacitors I should try to replace?  Unfortunately, there isn't any obvious bulging or leaking.
Offline bob91343
Re: Debugging an ATX power supply.
« Reply #1 on: September 01, 2020, 12:38:27 am »
Schematic diagrams are available online.
Offline darkstar49
« Reply #2 on: September 01, 2020, 11:16:30 am »
facing similar issue with an oscilloscope power supply (other thread...), but if it uns for 5+ minutes first, I'd rather suspect a thermal-related issue.
If I got it right, when you let it cool down, you're good for another 5 minutes, correct ??
If yes, I'd be really surprised if one of the electrolytics was the problem... keep us posted !!
Offline PKTKS
  • Country: br
« Reply #3 on: September 01, 2020, 02:50:42 pm »
Most of the time a generic rule of thumb in these cases...
- If one capacitor is already presenting problems (dry.. heat.. bad manuf.)
 => replace them ALL  or just in case ALL from same brand or model
- The ALL case is not cheap - the cheapest thing to do is replace ONLY ONE
- If ONE CAPACITOR is faulty you may have luck to spot them visually
OR... by using LCR techniques in which removing them (and discharging)
for testing is the best method.
I my personal opinion if would remove anything ... I rather replace it.
Paul
« Last Edit: September 01, 2020, 03:20:56 pm by PKTKS »
« Reply #4 on: September 02, 2020, 12:28:39 am »
Yep.  Could still be the caps, though.  I haven't quite decided that it's worth fiddling with; after all, new computer ATX power supplies are very cheap...
Offline Haenk
« Reply #5 on: September 02, 2020, 07:05:36 am »
The ATX supplies are really cheap nowadays, buying a working used one is probably aven cheaper. Even cheaper than the replacement parts :)
And don't use it with your computer, when the PSU starts to act up, evil things like voltage spikes might happen. Which are obviously not a good thing for sensitve computer parts.
