I have a baby monitor that is acting up.
the receiving unit appears to be very soft in volume.
I do not know if its a sender unit problem or a receiver unit issue.
I suspect its a sender unit issue - specifically the microphone, so i bought another cheap electret microphone to replace it - volume is much louder but it resulted in constant static as well.
now i am at a loss and do not know what to do else to test/troubleshoot. is it just the wrong microphone i bought?
original microphone has a DC resistance of 1.26kOhm. no symbols or numbering to indicate maker or model.
open voltage on the end of the wires to the microphone is 2.8v
microphone connects to TP99 (+) & TP100 (-) on the bottom of the circuit.
is it a microphone issue or another common component that can be easily replaced?
I do not have a signal generator , just a basic multi-meter.
thanks.
A
