Author Topic: dell 2209wa monitor  (Read 880 times)
Offline m3vuvTopic starter
dell 2209wa monitor
« on: April 19, 2021, 01:01:47 pm »
hi all,ive just brought this non working monitor,all that happens on power on is the standby light in the power button flashes amber briefly once about every 5 seconds,checked various voltages on the main board,they rise and fall in sync with the power button led,all fusible resistors look ok,any ideas,will try and attach the service manual if it lets me,cheers in advance,ps,all the caps check ok for esr.the service manual is too big so heres a link:https://www.manualslib.com/manual/794321/Dell-2209wa.html
Offline madires
  • A qualified hobbyist ;)
Re: dell 2209wa monitor
« Reply #1 on: April 19, 2021, 01:30:21 pm »
Shorted diode at the secondary side? Shorted load? Feedback problem? Issue with the power supply of the switching controller?
« Reply #2 on: April 20, 2021, 09:05:23 am »
sorted it,it was a shorted schotty rectifier diode,replaced it with one from an old smps,works fine now,brought the monitor from ebay as spares or repair,not bad for £19 and a couple of hours work.
« Reply #3 on: April 20, 2021, 03:32:02 pm »
wll it lasted about half hour then went off,found the diode was shorted again,the original was a   mbr5200
ive took a rf1601  tied the outer legs together mounted it on a heatsink,its been running for about 1hr and seems fine now.,its basicaly 2 diodes in paralell with a vf of 300mv.
