Author Topic: Dell 2210 LCD displays  (Read 3269 times)
Offline casinadaTopic starter
« on: November 04, 2015, 12:09:02 am »
I have a few Dell 2210 that have the same problem, They are too bright on the right side of the screen. I tested the fluorescent lamps and they work, I removed the capacitors of the digital board and tested them, and replaced them. I also tested and replaced the Capacitors on the power supply. Has anybody come across the same Problem? The LCD is an LG LM220E1(TL)(P4)
Any help would be greatly appreciated. It would suck to take these displays to the dump.  :(
Offline Rasz
    • My random blog.
Re: Dell 2210 LCD displays
« Reply #1 on: November 04, 2015, 02:42:32 am »
I dont think thats backlight, black monitor still has full backlight on, light is blocked by the lcd itself
Offline olewales
« Reply #2 on: November 04, 2015, 09:57:27 pm »
I second that. Seeing that darker strip on the right side of the display my first guess would be moisture in the LCD itself. Maybe layers from which the panel is constructed (polarization films, etc) are separating? Does the image change when you press gently on the display?
Offline Rasz
    • My random blog.
« Reply #3 on: November 04, 2015, 11:03:10 pm »
I didnt even notice that darker strip :0 wanted to write bias voltage, but its rounded!  it does look like something unglued/separated
« Reply #4 on: November 04, 2015, 11:39:43 pm »
My pictures are terrible, I admit but there is no humidity here in Arizona. If anything, it is extremely dry. The extra brightness is green in color. I will try to take a picture of the screen when is connected to a computer. These particular monitors fail way too soon. I was able to repair a couple with different problems and they come from different customers. I have 5 in my garage with this problem  >:(
Thank you
Offline olewales
« Reply #5 on: November 05, 2015, 12:57:31 am »
Did all of them get this green tint in the same area?
« Reply #6 on: November 05, 2015, 03:47:12 pm »
yes, they all are failing the same way.
Offline Rasz
    • My random blog.
« Reply #7 on: November 07, 2015, 11:47:48 am »
is it still green on white background?
even bad lamp wouldnt shine thru blacked out lcd, so I guess those TN panels are pretty shit
Offline Rasz
    • My random blog.
« Reply #8 on: November 11, 2015, 06:00:01 pm »
might be just degradation due to temperature - led strip is on right side
like here:
