Author Topic: dell inspiron 1720 random turn off  (Read 3082 times)
Offline p.larnerTopic starter
« on: February 26, 2024, 10:25:53 am »
i have a 1720 running win7 64bit and a t9500 cpu+ 4gb ram,it has started shutting down at random,i assumed it was overheating due to the cpu upgrade,i cleaned the heatsink+ replaced the thermal paste,it made no change,i notice tho if i remove the battery its fine,its a chineese replacement battery about 6 months old,is this a common issue,is there a fix?.
Offline tunk
  • Country: no
Re: dell inspiron 1720 random turn off
« Reply #1 on: February 26, 2024, 02:11:59 pm »
If the new CPU draws more power than the old, then the PSU could be marginal.
The following users thanked this post: p.larner
« Reply #2 on: February 27, 2024, 02:48:29 am »
did i say it is ok on mains with the battery removed,it only does it on mains power with the battery in the lappy.
