Author Topic: SMD cap identification please  (Read 209 times)
Offline tony359Topic starter
« on: January 17, 2025, 11:52:49 pm »
Hi all,
Could someone help me identifying brand and series of this SMD capacitor? it should be a 10uF, 35V.
I doubt it's a "Panasonic FN" series as the marking doesn't match what the datasheet says - plus Panasonic SMD caps have a much darker ink somehow!
The only thing I can find similar to an "SL" series online would be the generic "Multicomp" ones from Farnell but the datasheet doesn't say anything about the marking. This is assuming that "V" stands for 25V and "SL" is the series?
Thanks!
« Last Edit: January 18, 2025, 12:02:08 am by tony359 »
Online coromonadalix
Re: SMD cap identification please
« Reply #1 on: January 18, 2025, 04:25:34 am »
fn  could be the lot number ?
Offline parawizard
« Reply #2 on: January 18, 2025, 08:43:34 am »
Are there more caps on the board that are similar? Any pattern in manufacturer?
« Reply #3 on: January 18, 2025, 09:49:13 am »
I think I found them.
The 10uF and 1uF are the SL series, it's an obsolete Rubycon one. The marking matches the case
https://www.rubycon.co.jp/wp-content/uploads/catalog-aluminum/SLV.pdf
And I made a mistake, those 10uF are 35V, not 25V.
The 1uF is also the same series.
The 100uF should be this one: https://www.digikey.co.uk/en/products/detail/rubycon/25TXV100M6-3X8/3568657
But discovering the 10uF series was my main goal so happy days. Thanks for your help!
