Author Topic: Dell latitude e5440 shutdown after 3 sec  (Read 1216 times)
Offline hpibmxTopic starter
  • Country: my
« on: November 09, 2021, 08:41:43 am »
I put my laptop on sleep for few days didn’t wanna miss where I left.
Yesterday just pressed power button came on high fan and shuts down. Just all of sudden Sutton on my table.
I’m repairing phones and tablets. Not experienced with laptops.
I’ve look around motherboard for short didn’t really find anything.
What would be the cause?
Thank you.
« Last Edit: November 09, 2021, 02:04:03 pm by hpibmx »
Online mikerj
Re: Dell latitude e5440 shutdown after 3 sec
« Reply #1 on: November 09, 2021, 10:43:05 am »
Go through the basics, remove memory modules (ideally one at a time if there are two), hard drive etc. and see if behaviour changes.
  • Country: my
« Reply #2 on: November 09, 2021, 01:50:23 pm »
Sorry forgot to mention yes I’ve done all those. Still the same
Offline abdulbadii
« Reply #3 on: November 09, 2021, 02:06:53 pm »
thermal paste age ? feel the heatsink if not hot ~85 C so overheat too soon
Offline amyk
« Reply #4 on: November 09, 2021, 02:33:26 pm »
Unplug, remove the battery and hold down the power button for ~30 seconds to drain any residual charge for a true cold reset.
OEM model is Compal LA-9832P. You'll find the schematic if you search for that. Power rails and sequencing information can be found there.
Offline McBryce
« Reply #5 on: November 09, 2021, 02:56:14 pm »
Check the PCB for cracked ceramic capacitors, especially around the area of the power switch. I've seen this on several laptops that had the same symptoms.
McBryce.
  • Country: my
« Reply #6 on: November 10, 2021, 12:00:58 am »
Yes correct about 4 months old. And a free diagnosing I put them back to prevent quick overheat. Thank you
  • Country: my
« Reply #7 on: November 10, 2021, 12:04:19 am »
I’ve done that too, yes that’s correct and have downloaded the schematic was looking for brd file as well but I guess no need. I’ve looked everywhere done my measurements didn’t find any short at all. On main power rails. Around cpu around gpu. Lower resistance but no short at all. I’ve 3.3v present 5v and 19v.
  • Country: my
« Reply #8 on: November 10, 2021, 12:08:59 am »
McBryce.
Okay I’ll go through again and look closely but really couldn’t find any faulty cap.
