Author Topic: Dell Optiplex 390 Desktop PC  (Read 563 times)
Offline Carl ETopic starter
« on: June 29, 2020, 08:23:16 pm »
Hello,
This forum was so helpful in fixing a 2231 O'scope, I thought I'd try the forum again. My Dell Desktop died.  :scared: It starts up for about 2 seconds and then turns off. I have to push the start button several times before it wakes up. I've replaced the Cmos battery and that didn't fix it. I'm ready to buy a new supply but I'm hoping someone may have a suggestion of anything else to check before I lay out some cash.
Any help is appreciated.
Carl
Offline up8051
Re: Dell Optiplex 390 Desktop PC
« Reply #1 on: June 29, 2020, 08:45:29 pm »
Probably dried capacitors in the power supply.
I had similar symptoms in the Dell Optiplex 755, five capacitors replaced and PC works agin.
« Reply #2 on: June 30, 2020, 12:07:11 am »
SOLVED,
  Well it looks like this is a glitch in the ""I didnt ask for this software update that you just rammed down my throat'.  After removing the power cord for 30 minutes, it booted like normal.  I did check all the voltages on the power connector and they were in spec.
Bad Microsoft !! >:(
Thank you all for the reply.
Carl
