Author Topic: Wellon VP-180 Programmer  (Read 2359 times)
Offline ChrisLX200Topic starter
« on: September 21, 2017, 02:14:21 pm »
I've had this Wellon VP-180 programmer for years and recently needed to program a small PIC. Sadly, when connected to the computer the programmer failed to initialise and produced an error suggesting a hardware failure. So with nothing to lose I take it apart and look at the PCBs. I notice on the underside of the top board (holding the ZIF socket) one small surface-mount transistor (Mosfet?) had tiny a blow-hole in it, I needed a microscope to spot it! This and all the similar nearby devices have the marking HY2D and nothing else, and I totally failed to identify what this component actually was.
So again, with nothing to lose, I unsoldered that device and replaced it (hand soldered) another no-name component salvaged from a scrap PCB (a DVD writer). It didn't work first time and I got the same error, however I repeated using a different component and I thought I was successful this time because now the programmer initialises correctly and also passes its self-test routine found in the programmer software. Success? I can't really say because it still failed to write code to my PIC chip. Maybe the chip is faulty but I still have the nagging doubt that - despite passing its self-test - that replaced component was not correct. I don't even know if it is (was) n-chan, p-chan, NPN, PNP or what the heck. The programmer definitely reads chips just fine, but whilst the self-test includes an 'Output Test' I'm not sure it actually tests output voltages or it's just a logic thing.
Yeah, this isn't the way to execute a repair, so if anyone knows what the specs are for the failed component (HY2D) I might have more confidence in it.
Edit: Ah.. no. It's a fail. I tried to test some simple logic ICs and it fails to recognise them. I'm guessing when it tries to apply voltages to the pins it fails.
Edit2: Squeezed a through-hole n-chan mosfet onto the SMD pads (don't have SMDs in stock) and still fails. I think I'm done with this, I have a MiniPro TL866A on order which is modern and better software.
ChrisH
« Last Edit: September 21, 2017, 09:43:33 pm by ChrisLX200 »
Re: Wellon VP-180 Programmer
« Reply #1 on: September 23, 2017, 10:28:38 am »
Just out of interest - I would still like to know what the component was that failed. In the photos below it is the SMD transistor (V37) lower-left  which is replaced in the first image with a no-name tranny allowing the programmer to pass a self-test (but failed to write), and shown again replaced with a THD mosfet in the second (failed the self-test). I would still be able to revive this programmer I think with the right component.
Also shown is its replacement - the TL866a, here I made a couple of ISP connectors from F-F patch cables, hot-glued and wrapped with heat-shrink. Work just fine.
ChrisH
« Last Edit: September 23, 2017, 10:31:46 am by ChrisLX200 »
Offline picburner
« Reply #2 on: September 24, 2017, 05:40:23 am »
The HY2D isn't a MOSFET but pnp transistors of the mmbt8550 type.
In my Wellon vp-380 they are simply marked Y2 and they are just pnp.
The following users thanked this post: ChrisLX200
« Reply #3 on: September 24, 2017, 08:40:07 am »
Many thanks for that info, I can try a repair again now :-)
ChrisH
« Reply #4 on: September 26, 2017, 06:19:33 pm »
Follow-up.
Managed to salvage a suitable PNP transistor off a HD controller card). Trick was in identifying exactly what I'd recovered but it was just about possible using the cheap TC1 multi-function test (albeit like trying to attach the component tester clips to the legs of a dead fruit fly...)
Anyway, I soldered it in place and buttoned it up - success, the programmer tests OK!
ChrisH
Offline cowasaki
« Reply #5 on: January 27, 2018, 04:31:38 pm »
Does your VP-180 work?  If so do you have any 74xx ICs about?  Will it test them?  My VP-180 has just been dug out and seems to read EPROMs but fails with NEARLY every 74 series IC I've only found one (74241) which actually results in PASS.
« Last Edit: January 27, 2018, 05:01:03 pm by cowasaki »
« Reply #6 on: January 27, 2018, 05:57:06 pm »
It works, but there are no drivers that will communicate with it under Win7-64. I had it running on an old Samsung NC10 netbook under XP but that has an 'issue' at the moment! Wellon stopped supporting the VP-180 so no new software available :(
Offline cowasaki
« Reply #7 on: January 27, 2018, 06:37:58 pm »
I'm running it under Windows Vista using VirtualBox on two Macs!  You could run it under VirtualBox on a 64bit PC I would guess.  I'm thinking that maybe I could write a logic tester program in C for the Arduino.  The actual board would be simplicity itself and I've thought up how I could do each IC.
