Author Topic: Saleae Logic Pro 8 - Tracking down IC from markings  (Read 682 times)
Offline tfranco_apexar
  • Country: ar
« on: March 22, 2018, 01:42:37 pm »
Hello,
I have a Saleae Logic Pro 8 that isn't working. From what I can tell it seems the following IC is damaged, but I haven't been able to ID it. |O
The markings are as follows:
QAA (or QRA)
LG2
* D
(the * being the dot for pin1)
I found an undamaged one on the board which has clearer markings, photos of both are attached.
I'd appreciate any help recognizing the part or telling me where one could search based on the component markings.
Thanks
Edit: The package seems to match the 0.76mmx0.76mm WLCSP4 and is very reflective, rather than the usual opaque covers.
« Last Edit: March 22, 2018, 02:18:10 pm by tfranco_apexar »
Offline Zucca
  • EE meid in Itali
Re: Saleae Logic Pro 8 - Tracking down IC from markings
« Reply #1 on: March 22, 2018, 03:04:41 pm »
ehm... contanct Saleae, is the warranty still up?  ;)
  • Country: ar
« Reply #2 on: March 22, 2018, 03:07:13 pm »
I have, I'm waiting on a reply.
Not sure on the warranty though, but I'll post whatever the reply was.
Offline 0xfede
« Reply #3 on: March 22, 2018, 03:09:12 pm »
Hi tfranco_apexar,
it should be a NCP115ASN180T1G from ON semiconductor.
You can find the datasheet here:
http://www.onsemi.cn/pub/Collateral/NCP115-D.PDF
Best,
0xfede
Semel in anno licet insanire.
The following users thanked this post: tfranco_apexar
  • Country: ar
« Reply #4 on: March 22, 2018, 03:15:53 pm »
Thanks but I don't think that's the one.
 I have looked through some LDOs, I think it's smaller than a XDFN4 and seems to have different markings than that one.
It's kind of hard to measure with a caliper while on the board, so maybe you are right and it's a 1x1 IC.
« Last Edit: March 22, 2018, 03:24:08 pm by tfranco_apexar »
Offline 0xfede
« Reply #5 on: March 22, 2018, 03:20:55 pm »
Smaller than 1mm x 1mm?
The marking is QAA by te way.
  • Country: ar
« Reply #6 on: March 22, 2018, 03:25:59 pm »
I think you're right.
Thanks
Only thing is that the QAA should be for the TSOP package, not the XDFN4, so it wouldn't match 100%
« Last Edit: March 22, 2018, 03:28:53 pm by tfranco_apexar »
The following users thanked this post: 0xfede
  • Country: ar
« Reply #7 on: March 22, 2018, 04:56:18 pm »
Got a reply from their support:
"looks like one of our load switches blew. If that is the case, then it's possible other components may have been damaged as well.
I'm happy to process a warranty replacement for you."
It's been less than 3 years so it should still be in warranty, I'll just have to figure out if the mailing outside the US is a problem.
« Last Edit: March 22, 2018, 05:45:31 pm by tfranco_apexar »
