A guy I know called and offered me a Tek 11801 with an SD-26 sampling head for $100. He said it powered on. I told him I really didn't need another scope and he talked me into taking it for free. If I saw value in it in the future, then I could give him the $100.
I didn't power on. I swapped the power supply with one from an 11301, still no power and after a lot of screwing around, I found the power on switch to not be working. I wired up the switch and then it hung on comm diagnostics. I found a way to bypass them and also a note about taking U500 and U501 out of the battery backups. It then got past the diagnostics and seems to be working. I haven't got a trace yet for some reason, but all the controls work, etc. I have a cable running from the calibration port, still no trace, but I'll figure this out.
Every now and then I get a "Internal software error, Power off and on" with some hex code below it.
I suspect this is bad ROMs? Any ideas?
Any other pointers will be appreciated as always. I still have no money in it but it does seem interesting to play around with, assuming I get a signal.
Thanks,
Jerry
