Quite the BBQ
. What component used to be where the now charred PCB is ?. hmm.
Also the melf resistors in the middle of the last pic have bits blown of the side (surge damage) and most likely open cct.
The 8 pin IC nearby looks cooked too. Do any of the ICs have readable part numbers, can't tell from the photos.
Sadly though this unit (or the damaged PCB at the least) looks to be beyond economical repair without any cct. details to start with.
If you still want to proceed, the whole charred area has to be removed to get rid of conducting paths especially if high voltages are in that area.
Then finding out what part was burnt to a crisp and other parts damaged identified and are actually available. etc etc.
Of course the manual is a must. (hopefully someone reading this may have one !).
