Hello again !
It's been a month since I've worked on that receiver. From the beginning, even before my mistake (shorted one power transistor collector pin to heatsink), I suspected the main cpu (Sony CXP740096) to be dead ! This receiver, even if there was a fault, should at least turn on the display and flash a led to indicate the fault ?? So this is what I did:
I soldered 5 small wires directly to the cpu pins (VREF, VSS, VDD, RESET and AVDD)
I just plugged the receiver, did not push the ON/STANDBY button and measure these voltages:
VREF = 5.25V
VSS = 0V
VDD = 4.96V
RESET = 4.94V (active low, so correct)
AVDD = 4.97V
Checked the murata oscillator (on-chip grounding cap) if it was working, one pin at 0V and the other 4.95V, so not working !!
Removed the murata, soldered a crystal oscillator with two 27pF, like what I do with my microcontroller project and still one pin at 0V and the other at 4.95V !!
So my final though, the main cpu was dead from the beginning .... Not wasting more time on that receiver !!
But what do you think before I throw away (recycle) this receiver !!
