Trying to repair the above unit but getting a bit confused.
I have checked all voltages and the line labelled +5V_DSP was missing, all other voltages appear to be OK.
All output transistors and the low value resistors on the driver board also test OK.
I have removed all boards and replaced the 5V regulator, then replaced all boards EXCEPT the DSP, Tuner and any video boards (I think this is the minimum required to power the system). The system will power on (5V DSP present) and no flashing or protect errors, but I get no audio. I then discovered that the 5V DSP line has gone down again although there is nothing that I can see on the schematic connected to it!
Am I making some rookie mistake here? Can email SM if it will help but I think that it is too large to attach.
Any help or advice would be much appreciated.
