Author Topic: Denon AVR-1910 power amp repair  (Read 2373 times)
Offline RutherbergTopic starter
« on: February 15, 2018, 10:53:53 am »
I have a Denon AVR-1910 here with a pair of power transistors shorted on the front right channel (Q1201 & Q1202), resulting in blinking red led when powering up the unit.
Is there other components to check/replace by default when power transistors are shorted ? I attached the power amp schematic.
Thanks in advance
« Last Edit: February 15, 2018, 11:05:03 am by Rutherberg »
Offline willb
Re: Denon AVR-1910 power amp repair
« Reply #1 on: February 15, 2018, 12:00:40 pm »
I've repaired a lot of these Denon receivers with failed outputs. You definitely want to check R1231FR, R1232FR, R1238FR, R1239FR, R1236FR, R1237FR, and D1201/1202- Z1201/1202. The emitter resistors always go open on these, and I usually find at least one of the SMD zener diodes to be shorted.
The following users thanked this post: mzacharias
Offline mzacharias
« Reply #2 on: February 16, 2018, 08:08:14 pm »
I could fix these and similar models all day long. Did warranty work for Denon for over 20 years. Retired now but I still keep a stock of those output transistors, some original zeners, etc and a few scrap boards around for the odd small parts. I miss doing these on a regular basis. I do occasional work for a couple shops in town but rarely any blown channels anymore.  :'(
Offline rfengg
« Reply #3 on: February 22, 2018, 11:49:25 pm »
Glad you could trace it to the output transistors.
As far as I know, the protect kicks in when the Safe Operating Region of the transistors is exceeded, thermal excess  or when there is average DC on the speaker outputs.
I fought a losing battle with my AVR 1512 which used to kick into protect randomly.
So what did I do?  :horse:
Disabled the ASO_DET line which was the offending signal causing it to go into protect and have been using the amp fine for 2 years now......of course, with a fire extinguisher next to the 1512, just in case.............
« Last Edit: February 23, 2018, 12:07:50 am by rfengg »
Offline apellegr06
« Reply #4 on: August 06, 2020, 12:24:56 pm »
@Rutherberg Have you finally found the problem ?
Because I have a similar one.
Regards
Alain
