I just received a Denon DRA-335r. It is playing perfectly fine, however there are some issues with it.
The first problem is that the display is flickering irregularly. Could this be a problem with the 5v line or is the display dying? I tried to find IC605 (7806), which is responsible for the 5v, but I can't seem to find it anywhere on the board.
According to the schematics it should be near by D604, D605, C644 and the bridge rectifier. However D604, D605 and C644 are not near the bridge rectifier, infact they are on the other side of the board. According to the schematics, these components also appear (?) on the Tuner side, with IC604 (7812). I do measure 5v on D604 but IC604 is running very hot, I can bearly even touch it.
Here is the service manual:
http://www.manualslib.com/manual/720679/Denon-Dra-435r.html#product-DRA-335RThe second problem is the remote volume control, I can turn the volume up but I can't turn it down with the remote. All functions on the remote work, except for volume down. I measured IC251 (BA6109) on pin 5 and 6, which are Forward and Reverse for the motor. I do measure voltage on pin 5 when I press volume up on the remote, but I don't measure anything on pin 6 when I press volume down.
The remote does send out IR when pressing volume down..
Where can I start measuring? Any suggestions are welcome!
