So ThunderThumbs was removing the keytops from a recently acquired HP3330B Automatic Synthesizer to wash them, when he broke two of them.
One is just a cracked open keytop, and should be quite easy to repair.
But on the other, the "tang" on the keyswitch that clips into the keytop has snapped off.
The switch's sliding shaft reduces from a wider shoulder to the thinner tang that enters and holds the keytop.
So the tang needs to be reconnected to the shoulder, but it's very thin and weak. To allow for that, the repair would probably involve some widening of the shoulder and/or tang to provide some extra strength.
But less than 1mm of the tang is outside the keytop, and when fully depressed, less than 2mm of the shoulder is outside the switch. So any method of rejoining the tang onto the shoulder must involve less than 3mm of material wider than the shoulder, or else the key either won't depress fully, or sit higher than the other keys.
I'm hoping someone has a clever way of rejoining these two. Thanks for any help or suggestions you can provide.
The cracked keytop and the broken tang, and a good keytop that the tang would mate with.
The broken keyswitch (top left) missing the tang.
