Dear SMDude!
So i took another go at it, took off all the resistors, and caps, and the op-amps as well. Cleaned the board again, and tried to remove that black juice.
Tried different mehods (alcohol, windex, etc...) no help.. finally i went with fine grit sandpaper. That did the trick.
Then i re-tinned the leads, and checked continuity as well (cheat pcb was above, so i could check what is damaged.)
I found an open lead, which should have been connected, but the corrosion damaged it. Unfortunately i had no time to finish, but it`s promising.
It`s R115 bottom pad. (power rail side) coming from CH109 cap. I attach some pictures as well.
This is not a spill, or a drink, but the juice from the SMD capacitors (i am suspecting the 0805 size ones) since,the corrosion is next to those caps always.
I am curious, since they leaked their insides, did i measure the correct capacitance? Hmm. will see. Anyways, i got new caps, new resistors, new op-amps today.
Not the same model of op-amps, but njm2115`s i hope they will do just as good. In case not, i have some lm833`s as well.
Thanks for helping me out with your opinions!
Please feel free to evaluate my smd work, i am really a beginner in this size. i take any hints, ideas with gratitude!
Cheers: Titus
